Aluminium texture will not be rendered at far away range.
Aluminium texture will not be rendered at far away range(10-20meters away).
29884744257.html (493 KB)
Imgur
Enscape lastest version , Sketchup Pro 2018
Hey @vimut2020 , welcome to our forum! :slight_smile:
We’re yet unable to reproduce this problem ourselves so is there any chance that you could share the project file with us? You can simply upload your project hereand post the provided downloadlink afterwards. If the project is confidential, you may also send me the link through a personal message or via .
Thanks a lot in advance! :wink:
@vimut2020 And an explanation about what should be displayed as Aluminium would be of interest as well.
I can’t see an issue right now in your picture.
https://we.tl/t-NwEnnCvN13
here is the file… the aluminium rails are looking good in the near distance, but faraway they appear to be white.
Thank you for your concern.
Hey @vimut2020 , thank you for the project file. This behaviour you’re experiencing is due to a known problem where the back face material of an object is appearing through the front face material, visually replacing it in the distance. We’re busy resolving this problem as soon as possible.
In the meantime, we advice to simply assign your aluminium material to both the front and back face of your rails. Let me know in case you have any further questions regarding this procedure. :slight_smile:
Thank you. :slight_smile:
