ambient occlusion and physical camera
Hi all,
Im using the physical camera and Id like to run and ambient occlusion pass… Now I have about 15 cameras in the scene, there all settup for the lighting/gl of the scene.
The problem I have is that if I turn off GI/light, add a material with a dirtmap in the diffuse slot, with self illumination at 100%, all the physical cameras render the ambient occlusion very dark (as you would expect because Iv turned all the lights off)..
Now is there an easy way to fix this…remember I have about 15 cameras all setup up, I dont really want to have to change all of there iso and shutter speeds to make the AO bright…and then change it back again after the AO pass?
turn off exposure in the vray camera.
yep, that worked a treat!!!
cheers
