Ambient Occlusion vs Dirtmap
Couldn’t you just duplicate the AO pass and invert it to get the Alpha you need?
‘almost’ black (maybe like 254,254,254).
You would need some INVERSE glasses to see the black like that. 8) 8)
nikki Candelero
How about a method of projecting the VRay Dirtmap unto the scene without using the material override feature, that way we can render the dirtpass over the top of our scene in one pass. I am able to do this using the MR AO material and have seen it done with turtle.
I know this means a lack of flexibility later on, but it does negate the need to comp the dirtpass later.
Colin
why not use the AO render as a luminance alpha controling another layer. for instance you can tint that other layer, increase intensity etc and the luminance map AO render will controle where that other layer is being placed
Well, yes but wouldn’t it be better if Vray had that “simple” option ? Cya.
If you do it as a projected map you only need it in one place and you dont have to edit loads of object materials or indeed add it to any new materials you create. In mental ray you can create a light, turn it off and put the AO material into the mentalray light shader section of the light, which then projects that info unto the scene.
It just seems to be an easy way of doing it especially with large scenes.
use the dirt pass in a mix map
I will give it a shot dude :slight_smile:
To be honest i’d prefer it if vlado spent his time coding more useful things.
This thread has given me such a bad headache, its a disaster.
Lol relax and I think it’s the artist who makes it usefull or not. I did missed that option but of course there are priorities, either way it’s good to give our feedback to Chaosgroup :slight_smile: Cheers
This is what I was trying to achieve.
This is straight from max, no comping of dirt passes.
There are 2 lights, 1 is the key light which is casting the strong shadows and the 2nd light is switched of but is projecting the ambient occlusion shader unto the scene, there by letting us render out the individual material colours and also you can see from the glass objects that the AO is visible through and the objects themselves cast shadows and the AO will be visible in the reflections in 1 pass.
This is what I am trying to achieve in VRay, yes I know there are other ways of getting to this, but there is no GI involved and works on interiors and animated objects too.
Ive said twice to do it with a mix map in your material and so has Da_elf. Please read the thread.
Does exactly what you want, dont even need any lights or GI and youve got far more control.
I know you have said it twice and so has Da_elf. I am probably slow on the uptake, but with a mix map dont you have to apply it to all your materials in the scene individually? if so then you have missed my point. I put the AO shader in 1 light and regardless of what I build/merge or change I do not have to fiddle with or add to that map. It is like a material override that overlays data through out your scene, but still enables you to see through to the underlying geometry texture data. Where as the way I understand the mix map method if i merge or create new scene information I have to manually “mix material with vraydirt in the amount slot, then your bitmap in the white and either a darker version or a different one altogether in the other” Yes I do know you can do it in VRay as shown below, but not controlled the way i suggest.
The VRay version
You do realise that you dont have to respond to this thread if it displeases you, it is of particular interest to me and I like to explore it further. For those interested you can download the scene from the link below, which elaborates my point more clearly.
mental ray
www.e3di.co.uk/test/AOmrtest.rar
vray
www.e3di.co.uk/test/AOVraytest.rar
Thank you all for your responses so far. :slight_smile:
Colin
We could pobably modify my colour correct script to apply a vray dirt map to the diffuse of every mat and put the previous diffuse in the white slot of the dirt - not perfect but might speed things up a tad.
Looking good. Up the subs and you’ll look the same as the MR version.
I like the override version too. Yes, it’s another step in post, but it saves a *lot* of screwing around with materials. Would be slick if in additional to “Override” there were an “Overlay” button. :slight_smile:
Hear hear, I would hate to fiddle with materials in a complex or large scene. Bring on the ubiquitous “material overlay” button :slight_smile:
For extriors with one key light the projector light method looks like it might be doable. Great idea I would never have thought that would work. :shock:
Aside from the superb divulgant description of a very bitchy technical issue, i’d like to say i smell a script coming…
:lol:
Lele
For exteriors in particular, you are way better off using the V-Ray light in dome mode. The results can be very similar.
I don’t want to be rude but I think that Vray light in dome mode is very slow compare to VrayDirt…
And option in the VrayMtl to add dirt is welcome…
Best regards…
PS : Vlado you do a great job…
