Include option to render Ambient Occlusion as a separate Render Element when we don’t want it baked in under Environment settings.
Hi, thanks for posting. Could you explain your workflow in a bit more details? You need the Ambient occlusion as render element for animations or still images? Do you plan to add it in post?
Hi, AO render element needed for still images so we can vary the opacity and paint out unwanted areas in post.
Hi, thank you for sharing. I logged you suggestion in our system as a feature request under LAV-1544.
Is this feature already implemented?
Can we render AO as Render Element
Hi filip_s,
No, AO as a render element is not implemented. Please vote for the idea here in the Idea Portal https://chaosvantage.ideas.aha.io/ideas/VANTAGE-I-93
Alexander
