i need this soo bad … in the interior scenes i got chairs sofas and tables flying and AO can hold it “back” on the floor …
but better way how to do it will be when sky light can cast shadows …
Currently in many circumstances the automatic ao settings do not produce a strong enough effect and element still appear to float.
@jan1 appears to be aware of AO, and has obviously missed the fact that Enscape is already implementing it. This would seems to confirm that the built in settings are not obvious enough?
@jan1 do you have an example?
Looks pretty good actually.. I can see the effect, but certainly some people would like it to be stronger. The pots contrast hides the effect there. The AO effect by enscape is also not the “sharpest” but it is also not bad either, keep in mind it is realtime.
There are other cues in reality that make an object appear grounded. For example it is pretty much impossible for a chair leg to rest on the ground exactly …one thing you can do is raise your elements off the ground slightly.
Many people use a stronger AO effect to make up for these missing cues… mainly because it takes A LOT longer to model all of them. I am all for shortcut like this btw
A renderer is a just tool to communicate ideas, and ideally we should be able to use any and all shortcuts that work for us. Another one I miss is rounded edges, but I do not think we will get this any time soon. More control over AO is lower hanging fruit.
If we were given an “AO pass” we could make up for this ourselves in post efficiently. This would seems to be a decent compromise if the Enscape team doesn’t want to clutter the precious UI ![]()
ok lets say AO is good but what i really missing is shadows from the sky …
The indirect shadows become more visible when you reduce die ambient brightness. Have you tried that?
There was a specific “AO” slider in the early releases of Enscape. Was SUPER useful. It was removed and integrated into one of the other “sliders”, I think the Ambient slider. It’s not as useful in the current implementation. Would be great to have the flexibility of having it back as an option…
I find chair legs fine. One thing that really floats is the plant pot. Too dark for my taste ![]()
It has simply been renamed. It is now called ambient brightness, which is the inverse. We thought that it would be more intuitive yet less technical. It is however not the classic AO that you know from other tools since we follow another approach in terms of light transport.
and what about AO on material editor ? sometime i just need enhance only picked materials …
Only specifying certain materials to have AO included is technically not possible. Still, if there is anything else I should file as a dedicated feature request, please let me know. ![]()
well can you add GI AO pass into channels export checkbox ?
