Here are two bad side effects only apparent when using AO:
In this image the lights - generate a negative light
In this one the light has a dark halo between the light and wall
the the only difference between both images is that the interior one has a shutter speed of 80 and the exterior of 100.
EDIT: After turning AO off it lingers but it wasn’t apparent prior to using SP3
Could it bee due to using photometric lights ?
or using the VrayLightMtl direct lighting ?
This doesn’t answer your question at all (this should probably be in the problems section) but I tend to agree with MA. At least do it in extratex and comp it in after.
I am not sure thayt the reason is AO but those black areas only appeared AFTER I switched the AO ON ans worse - they did not vanish after Turning it OFF…
