AMD Threadripper rig, good choice?
Hey guys,
Thinking about building an AMD Threadripper rig for rendering. First time DIY a PC here, so kinda excited and hope not step wrong steps. I use pcpartpicker for computability check but want to check with you 3D gurus to see if the rig is solid for day-to-day rendering of personal projects and upgrade potential for adding two or three GPUs in the future for GPU rendering.
Trying to keep the budget under $2000 and hence the GTX 1060 and 32GB of RAM.
Main concern: capability and stability for OC to 4GHz with the cooler…
CPU: AMD - Threadripper 1950X 3.4GHz 16-Core Processor ($799.00 @ Amazon)
CPU Cooler: Noctua - NH-U9 TR4-SP3 78.9 CFM CPU Cooler ($69.90 @ Amazon)
Motherboard: ASRock - X399 Taichi ATX TR4 Motherboard ($259.99 @ Newegg)
Memory: G.Skill - Ripjaws V Series 32GB (4 x 8GB) DDR4-3000 Memory ($299.99 @ Newegg)
Storage: Crucial - MX300 525GB 2.5" Solid State Drive ($129.99 @ Amazon)
Video Card: Asus - GeForce GTX 1060 6GB 6GB Dual Video Card ($249.99 @ Newegg)
Case: Phanteks - Enthoo Pro ATX Full Tower Case ($84.99 @ Newegg)
Power Supply: Corsair - CXM 750W 80+ Bronze Certified Semi-Modular ATX Power Supply ($69.99 @ Amazon)
Total: $1963.84 USD
Any comment will be appreciated.
cheers,
Jason
Seems great!
You will have 4 more RAM slots free for future RAM upgrade.
Best,
Blago.
Thanks Blago! That’s the plan for sure… :slight_smile: I am also a bit concerned the CPU cooler fan will be in the way of the closest GPU slot, making me surrender that slot forever. Then I can only put 3 GPUs maximum in the future…
It’s hard to tell based on the measurement/spec.
Hi Jason
I would go for water cooling on the Threadripper if you can.
I’ve been working on one the last 4 weeks and we got it with Corsair Hydro H110i, shouldn’t be much more expensive and no issues with space around the CPU.
Yeah Gavin, I was debating between water cooling Corsair H80i v2 (due to budget) and air cooling Noctua NH-U14S TR4-SP3. I was kinda convinced to go with air cooling after viewing this review on Youtube.
But then the size of air cooling does worry me if one day I need to crank a GPU using the slot closest to the CPU…
Are you OC your 1950x to 4.0+GHz with the Corsair Hydro H110i? If yes, has it been stable?
Very interested in something like this but ideally in a small form factor!
I would definitely splurge on the All In One liquid cooler if you can. It will keep temps slightly lower but it is also much quieter.
We did overclock but ran into problems with the motherboard having temperature issues before the CPU. It’s an MSI Carbon and apparently, MSI is working on a fix.
And as Jason said it is definitely much quieter.
hopefully a manufacturer will release a micro ATX board
That I would like to see considering the Threadripper CPU is almost the size of a business card lol
To the OP I hope its a good investment as I just build my first Threadripper lol. So far I’m very happy with the performance but time will tell…
Thanks guys! I have received everything except the motherboard. I missed the deal to snap a $250 ASRock Taichi…went with his bigger brother ASRock Pro Gaming motherboard…
