Ah, ok, I did not know about the gizmo feature in conjunction with the render mesh option. That helps a lot. It is in the docs, so I should have get it there. Still I would say this feature could be named more like what it does instead of just “gizmo” in the UI and grey out, when render mesh is on. Especially when calling it gizmo, I first thought only atmospheric gizmo objects could be used for that.
I have attached two videos, both using Forward transfer in the upper container, one with a non-penetrating emitter where the quantity just fades away and one with a penetrating emitter, very nice and stable behaviour - but still about three times the volume in the second container.
Thanks,
Bob
FT_tests.zip (2.22 MB)
