An application error with cproxy
Hi!
Sorry for my perfect english!
Ihave a problem.
An applicarion error appears when I use Cproxy, set up a square on viewport, put on “pick from scene…” and move the mouse cursor to a viewport. As soon as I move mouse cursor to viewport the error “an error has occurred and the application will now close” appears.
Please help me!
I need to add objects to proxy! :frowning:
Which version of Max and Corona?
Can you send an example scene? Or at least a few screenshots showing what exactly you are doing and what is happening?
Thanks in advance!
It is MAX of 18th version. It doesn’t matter if there is any object ot there is not. When cursor of mous gets to viewport a reciese the error.
Which version of Corona are you using?
Cheers,
Rowan
Corona 5.
Please send us the mini-dump which was produced from your 3ds max error (upload using our private uploader: Chaos)
, to acquire the file please see the following guide: https://knowledge.autodesk.com/support/3ds-max/troubleshooting/caas/sfdcarticles/sfdcarticles/Where-to-find-3ds-Max-dump-dmp-files-on-the-local-workstation-after-a-program-error-crash.html
There was a bug with Corona v5 HF1 which caused a crash when using the pick from scene button in a cproxy.
Please also try using v5 HF2 or even better Corona v6.
Cheers,
Rowan
Instolling of corona 6 have solved the problem! Thank you!
