An internal error occurred: wxWidgets assertion failure - While rendering in VFB
Hello all,
I keep getting this msg while rendering in VFB
I’m on Mac 10.14.6 - Mojave
c4d R21.207 - corona 6 30/06
Hi, thanks for reporting this. We have it logged internally and I will update you once I have more information.
For internal use: (Internal ID=540735980)
Can you also share a video of this happening? We need to know exactly where and what you are clicking when this happens. If so, please share it via our private uploader here:
I have the same bug and some additional ones, for me it even crashed. It happened while I was working on the curve from the VFB. If the bugreport doesn’t show any personal information, I can upload it here. Unfortunately I can’t upload the scene or isolate the problem (had this issue on other scenes as well).
Best,
Ararat
Hi Ararat,
You can sleep easy knowing that bug reports have no interest in your personal life :wink: Please feel free to share it with us.
Thanks a lot, because I’ve been sleeping bad lately :tongue:
Files are attached, hope they help!
_BugReport.txt (1020 KB)
minidump.dmp (8.22 MB)
Great, you get extra points for sharing the minidump too. Thanks!
Nookta, may I also request some additional info from you?
Corona version?
Cinema version?
OS?
Of course:
Full-speed non-debug version
Build timestamp: Aug 25 2020 09:52:16
Version: 6.0
Cinema version: R21.207 Cinema 4D (mutli-license)
Plugin status: Plugin successfully loaded
Windows 10 Pro Version 2004 (Build 19041.572)
AMD Ryzen 3950X
64 GB Ram
Nvidia RTX2080 Super
Best,
Ararat
Thank you. And finally, Can you give me some reproduction steps to try and recreate this error? You mentioned editing the curves in the VFB, was it running at the time?
Yes, the interactive render was running at 4000px and it is a medium scene (vegetation and staffage was turned off). But the LightMix was pretty heavy with maybe 10 HDRs and 5 other light selects. (We are creating three images from that scene) And as I said, I was editing the curve when the error ocurred. Then I clicked a few more times and some more messages appeared and then it crashed (while I was searching for this thread :D). The crash interestingly didn’t happen before, so that is new to me as well.
Okay, thank you. I appreciate the additional info. We will see what can be found in your supplied reports.
