An issue causing a reset of all Vantage settings when modifications are made in the Revit model during a live session is resolved
**“Thanks for the update, but unfortunately the issue still seems to persist on our end. Modifying the Revit model during a live session continues to reset all Vantage settings. Has anyone else experienced this after the supposed fix?”**​
Same thing in MAX!
Hello vincenzo_ferrara​ and glorybound​,
Could you please clarify which specific Vantage settings are being reset when you modify the Revit (or 3ds Max) model during a live session? There are some known limitations related to Live Link that might be relevant—please refer to this page for details:
https://docs.chaos.com/display/LAV/C…ownLimitations
Additionally, it’s important to note that if an environment is set in the host application, Vantage will inherit that environment through Live Link. This means that even if changes are made inside Vantage, the environment will continue to be overridden by the host app as long as one is defined there.
If your case is different and doesn’t involve this scenario, it would be very helpful if you could provide a short video demonstrating the problem. You can either share it here or submit it through a support ticket so we can investigate further.
Looking forward to your update!
Hello vincenzo_ferrara​,
Could you please submit a support ticket and upload there a simple scene where the issue is reproducible and a video demonstrating the problem?
