Creating a porch using VRAY 3.6 and Sketchup pro 2018. I started to mess around with the glass window neutral settings to see what they each did and try to get a more reflective or glossy finish. After messing with these settings, I decided to go back to how they were originally, by just dragging in a new glass material and deleting the old one. For some reason though, no matter what glass material I try, the render results in this distorted image. When the light hits the panes, it refracts perpendicularly to the pane. I attached photos to hopefully help describe the issue more. Sorry that they are clearly in different stages of progress, but the issue should still convey. I also thought that it could have something to do with changing between dome light and sun, and/or changing between cpu&gpu but neither of these have an effect.
Another question I have - Do most of you use glass panes that are just a plane? or do you give your glass some thickness?
Will comment with other photo, having trouble uploading on this post.
