Hi, Is it possible to render Anima 5 people with Vantage through max?
Thanks,
N
Hi N,
Please check the following forum thread Problem with Anima 4D People material - Vantage :: Issues - Chaos Forum
Alexander
Perfect! Thanks man!
I’ve run into the next common issue with the Anima 4D textures flickering. Is there a solution for this or a workaround?
I contacted AXYZ and they said a solution has been created, do you know when the next Vantage update (with the flickering fix) will be available?
Hi N,
With Live link rendering, Vantage relies on V-Ray and Anima4d to get the models. That is why the fix actually requires update from both V-Ray and Anima
As the people from AXYZ have informed you fixes are currently being made. With the release of V-Ray 6 for 3ds Max, update 1.1 on April 11 the fix on V-Ray’s side is now publicly available. You just need to wait for Anima to release their fix, which I am not informed when it will be. When you have both versions updated, you should be able to render Anima animated people correctly with the currently available Chaos Vantage 1.8.4.
Alexander
I managed to get the Anima 5 update and the flickering is gone, it works!
NorthVisualStudio what versions exactly are you on ? Tested with the latest Anima5 and Vantage and I still get the flicker while auto-rendering from max.
Vantage Version: 1.8.5, Build: 1690356, V-Ray 6 Update 1.1, Anima 5.0.3 RC6.
Ok, so it looks like the 5.0.3 version will come with the solution, good to know! I’m on the most recent stable, the 5.0.2 and the flicker is still there.
You should be able to get it here;
