Hi, it seems like it’s not possible to animate (that is; set keyframes) for the camera clipping parameters?
Is this correct? Any work-arounds available, if so?
Thanks.
EDIT: Oh, please ignore me! Sorry, it’s working now suddenly for some reason!
Thanks.
Be prepared for surprises though. There are still unfixed, even unconfirmed issues with frame changes, parameter block and Corona since years/ever - Corona Cam is also affected, you will not always get what you want if rendering a sequence.
Good Luck
Are you referring to “animating render element parameters” and/or “inconsistency between maxscript dr_enable property and actual state of dr”?
There are a few more, like for example #181819 (see comment there) or #14636. If I would setup a dedicated test scene, I would probably be able to find a few more. Not sure about “animating render element parameters”, cannot remember having issues with them, but I used it rarely.
Good Luck
