Hello there,
got a short question. I want to have displacement around a moving object.
Thought the best way to do that is the vray distant shader, but it doesnt seem
to work in the vray geometry tag.
any suggestions?
Edit: Something similar what you can do with the c4d displacer deformer and field falloff
Hello @folklore
I tested the Displacement and the animation works as expected by default.
Could you share with us a visual representation of what you are trying to achieve so we can assist you?
Sorry for coming back so late, but had to finish the project and forgot about this.
I attached a simple setup. It seems I cant get distant shader in the displacemnet tag working.
The color material works as intended. Where’s my error?
disp_distance.c4d (200 KB)
Hi folklore,
Please note that the 2D Displacement type is not working with procedural maps. If you switch the Type to Normal, it should work correctly.
