Animate exposure without rendering again
I have a scene and I want to animate exposure (or light intensity) but I don’t want to render each frame, as render one frame should be enough.
What’s the workflow for saving hundreds of frames of the same scene, if only the exposure is changing.
Saving a few frames and interpolating does not give the desired result.
Bring one frame into Nuke, add an exposure node, then animate the value over the frames. This would take 2 minutes, tops.
