Hi all, I should animate this value by moving it from 0w to 15w. I want to simulate the activation of LEDs.
How can I do this?
Hi, thanks for posting. You can not animate lights directly in Vantage. You can do this in 3ds Max or another host application.
It doesn’t work. I animated the lights in cinema 4d but in vantage *.vrascene remain fixed at 0w
work fine in live link but in cinema 4d it’s impossible to render directly with vantage as it happens instead in 3ds Max
We have this fixed for future major releases.
Greetings,
Vladimir Nedev
I’m not able to get animated lightvalues ( 3ds Max 2019 ) rendered with Vantage 2 either ![]()
Hi robert_ecker,
Can you send us the scene with animated lights so we can investigate?
Alexander
Hi Alexander,
i’m not sure why it’s not working - but i guess it’s because of the selected Fileformat.
As i said the animated lights + animated camera were made with Max 2019.
When sending it to Vantage via Toolbar → Render Animation with Vantage → choosing MP4 as outputformat the UI ist showing HQ sequence frame 1 of 360. it’s rendering the first frame but then it freezes.
When choosing PNG as output format it will render the whole animation inclusive the light animations.
