Hi!
I have a scene with several VrayPhysicalCameras animated in max. I export the scene in .vrscene format to vantage, and everything is ok.
In vantage I adjust the lighting using the sun and sky parameters.
The problem appears when I want to adjust the exposure value of each camera based on the lighting that I have created in vantage, since when I want to render the animation, the camera’s exposure values are reset to the original values imported from max, and If I try to update the camera in vantage I keep the exposure settings but I lose the animation.
Is there no way to preserve the imported animation from max and make adjustments to the camera parameters?
Thanks!
