I’m working on a simple animation, which has a cube changing material on impact. The material change happens via material tag and keyframing the “material slot”. I attached the simplified scene. When rendering frame 0 it works properly. When rendering frame range or any frame in the animation I get the “unsupported material” pattern in the frame buffer.
Can somebody help me with this? Is there a workaround for this to render?
I haven’t had the chance to try this with a more recent C4D version or a daily build.
Looking forward to your help!
Full-speed non-debug version
Build timestamp: Aug 3 2021 16:40:22
Version: 7.0
Cinema version: R21.207 Cinema 4D (mutli-license)
Plugin status: Plugin successfully loaded
Cheers,
Ararat
animated material tag issue.c4d (1.87 MB)
