It looks like the animate object visibility does not work with decals from my testing, (I am doing so via LiveLink) this would be really helpful so we can animate things like footprints etc.
It works in Vray GPU and CPU.
EDIT: I can get a version of it working as long as you go from 0.0 visibility to 1 in a single frame. When it is over multiple frame you get the attached image/
Are you sure about this ?
The setup I have works in V-Ray GPU, but not in V-Ray CPU.
The visibility of the decal object is completely ignored it seems in the CPU version.
As a workaround you can use a VRayColor texture connected to the Mask slot of the Decal object and animate its RGB multiplier.
The cutout texture of the decal goes in the opacity slot of the decal’s material.
This works in V-Ray CPU/GPU and Vantage.
See attached example file.
I will log the issue about the object visibility of decals in Vantage.
Apologies, yes I thought I switched to CPU as well, but just double-checked and CPU it is ignored.
Took me a while to get this working! I didn’t realise that you were NOT animating the visibility as well. After leaving visibility at 1, it works perfectly with the color in the mask slot and animating the multiplier. However, in my case animating the multiplier to 2 instead of 1 made it look correct, 1 it was still only semi-transparent.
My decal setup had a proper mask in the opacity slot of the decals material already.
