I am experimenting with animated proxies from animated Grow FX objects. Nothing fancy just plane materials for now.
It seems that there is some distortion going on at the beginning of the animated proxy (first frames).
Is anyone else experiencing this?
do you have motion blur enabled? If so, the last frames might be visible at the beginning as well. Try switching animation mode to ‘ping-pong’ or ‘freeze out of range’.
Let me know how it went. If the problem persist, can you give me the scene?
I dived a bit deeper in my problem and probabely it is a GrowFx issue.
I adressed it on their forum.
Little request though, can you guys add some tooltips or add an article on the help portal about the animation paramaters of the Corona Proxies.
I don’t have a clue what those “modes” do or when I need to use the “frame offset”. Many thanks.
