Animated Proxy mesh not displayed correctly
hello, as you can see the problem in the imageses when I change vray gpu, I encounter such a problem, what could be the reason?
do you have any solution? if I add editable poly problem solved but not animate
Does setting a small value (0.01) to the “Secondary Rays Bias” (Render Setup> V-Ray> Global Switches) make any difference?
unfortunately, it didn’t work, but I solved the problem by add the poly select
