Animated sun and clouds error
I’ve got an animated Vray Sun position and animated clouds and I get this strange white band across the sky that moves as the sun rises in the sky.
Sounds very similar to this thread. You could send us the scene to confirm.
Yes, that is exactly what I’m seeing. Has any solution been identified to fix this? My sunset and sun rise happen slower so it’s not just 1 or 2 frames that are affected.
Frames 115-132 in the attached max file.
sunset test.zip (2.08 MB)
It is identical, yes. Sorry to say, I have not been able to find a workaround for this one. However, I have notified the project managers about the issue so as to prioritize the issue.
