a sweep with animated growth is not rendering until the build up is finsihed, when motion blur is activated with DR2.
When I add an object prop tag and MB samples activated, it renders.
Without DR2 it is rendering without the Object Prop. Tag.
Is this a expected behaviour?
Hey @haniel1107 , to answer shortly on your question - no, it is not expected behavior. To elaborate - it is expected that animated growth will not render with motion blur effect (due to the changing topology), but it is expected to render as the object is changing.
I tested with making such a scene, and reproduced your issue (with the released version). It has been fixed internally and the fix will be included in future versions.
Hi @deyan.hadzhiev . Thank you. looking forward to the next release..
