animated texture
Hi there,
I was just wondering if you guys might know why my animated texture is showing up dark grey in escape? I’ve tried multiple mp4 videos but they just change to a solid dark grey colour once I’ve applied the texture. (this is after doing all the “coding” in the description part in revit) I’m not sure what I’m doing wrong as I’ve followed multiple tutorials step by step!
let me know if you can help :slight_smile:
@nomky001 , would you kindly also briefly send me a few screenshots of the project itself in which you try to apply the animated textures and another one of the material settings itself? Plus, if you disable “Restmode” in the General Settings → Rendering tab, does that make any difference? (It should not but just to make sure)
Hi Demian,
In the mean time I actually managed to sort it out, but as my problem isnt on the internet I thought i’d share for others!!
If you type in the formula in the material settings and then just press ok afterwards, " appear around the path. This makes the formula not work hence the grey box because it can register the texture change, but can’t find the path! After writing in the formula you must press apply and then ok to avoid the quotation marks being added.
Hope this helps others out! :slight_smile:
