im using vray clipper mesh object and ive noticed the clipper will be active for the first frame of animation but then wont be there for the next? However if you cancel and restart the render on the next frame it will be there?
Is there some work around for this? maybe if you create an animation key for every frame, or would you have to set the animated portion as 1 render job, then delete the keys on the clipper and set every subsequent frame as another render job?
