Is it possible to make 1 animated VRay proxy from an Onyx tree blowing in the wind, then instance or scatter or whatever the tree a bunch of times, and have the animation of each tree offset so that they don’t all look exactly the same?
Just throught I’d point out that, as far as I know of how the animated proxies work, if you want a bunch of them with different offset frames then you’ll need that much more RAM to load the different “variations” - each version of the tree with a different offset is effectively a different object for RAM requirement purposes.
Especially with trees that can be very polygon-heavy, this is something to keep in mind, IMHO.
Being the proxy dynamic geometry, unless you’re feeding it a heavy multi-bounce GI (like LC) you’re likely to have memory loads fairly consistent, no matter what.
Simply set the dynamic memory limit to however high you can, then render and forget about memory issues entirely.
I usually set mine to 7000mb for my 8gb machine. I’ve never tried setting it to 8192. I’d recommend leaving your system with at least 512mb of ram so if you have 2048mb of ram, type in 1536, and so on. I could be wrong in the way this works though.
There is no definate answer i’d say. As you cant predict wich apps/processes are open and consume/request how much memory at what time. Got a PS open ? tweak it…at least i thought that’s how it works.
Basically the memory you specify there is the upper limit, after which vray start unloading stuff from ram (as opposed to leave it there no matter what, with the static raycaster).
That is, there are cases where the dynamic raycaster doesn’t even need to swap stuff out of ram, as the upper limit isn’t reached during the render.
Have a 4gb pc? set it to a couple of GB and it should work fine (vray will warn you of performance loss in case that’s too small).
It’s clearly useless to set it too high (like 4gb on a 4gb pc.), as vray wouldn’t unload the stuff from ram even if windows swapped to hell, negating the idea of staying always in the faster RAM space at the expense of some ram swapping overhead (not disk swapping, mind you).
Of course, I’m ready to be corrected if I’m wrong
Have been thinking about trying to do the same thing with Onyx Trees, however, the main limitation would that these animated trees could not be rotated for variation, because the wind direction would different on each tree.
It would require several unique proxies that could then be instanced around the scene.
And has been mentioned previously, the proxy files would be quite large.
Yeah, and it simply looks noisy - you’d be surprised how much you actually recognize when things are off. In this case, it’s quite obvious that especially when trees are bunched together, you expect a certain directional rhythm.
