animating a curtain billowing in breeze
anyone got any good suggestions for animating a long white fabric curtain that blows slightly in the wind?
i want to use vray as the renderer
hi
are you going to use Sim Cloth ?
Unless you need colisions, you can try playing with noise modifier.
Select bottom row of vertices with soft selection enabled and large enough fallof to cover a lot of the curtain. Add noise to it, with large size and small movement rate. These can even be stacked to produce more complex results and each can have a different seed (quasi random pattern of movement).
Additionally.. you can slap a FFD deformer on a region for more predictable control.
Well Simcloth is without a doubt the best alternative. For one simple reason…it’s free.
If you plan to spend money I would suggest either Stitch or Clothreyes…mostly Stitch.
But check out Simcloth. It’s really easy. Even if you could use a noise mod. I still would suggest Simcloth.
Is using Reactor competely out of the question?
Being that it is built into max and everything..
-Tom
Well Reactor would do the job too
and it is build in allreadey. On the oather hand i´ve read, that cloth simulation of reactor is a bit slow and works better when you aply after simulation also a mesh smooth modifier.
I didn´t test it. But you should look at the example scenes of reactor. there you will find something nearly to the things you want to do. a curtain which is mooving from the wind, after the wind opens the window.
just take a look and it´s free also.
Tom :slight_smile:
