I have tricky question. I am animating a battle scene that uses chess pieces to represent the men. I want to be able to fun the pieces off as they die, I was planning on doing this with visability through Object properties.
It’s a two part question :
1. Is there anyway to view proxies in the viewport in a way that presents object visability ?
2. Is there an easy way to control and keyframe the visability of an object ? I tried a couple of scripts that allow you to key multiple objects none of which worked - it’s just such a pain in the arse to have to create the visability track through auto key and then more the keys around - maybe I’m missing something simple.
Thanks as always for you’re help
Adam
