animating the Output Amount of a map doesn't seem to work in VRAY CLOUD !!
i tried animating the output amount of a bitmap for 0.0 to 1.0 that i use in the opacity slot of a vraymtl and when i try to render the animation on the vray cloud it’s not animated at all !
But it’s working locally.
Is that feature not supported ?
I look in the docs and didn’t find anything relevant.
Can you please help as i spend many credits rendering for nothing :confused:
Thank you.
We will restore your credits if you email us to support@chaosgroup.com and explain the issue. We will also fix the animation export of the output amount parameter. Apologies for the inconvenience and please let us know if there are any other issues.
