Animating the size of lights, but not from centre?
Is there a trick to animating the size of a light? I have a rectangle strip light and I want to animate the size to illuminate part of an object. But I want the light to grow from one side and not the centre which it does by default. I thought maybe the Axis Centre node would do it but it messes with all the lights in the scene. How might I solve this? Would it just be to animate a shape that blocks the light and not the light itself?
You could also use geometry with CoronaLight Material applied - there’s no performance hit there except in the case of spheres. This would let you animated the changing rectangle with all the usual C4D controls for a geometric object.
What’s the axis centre node? I only know the Geometry Axis capsule and it leaves other lights alone.
geometry axis.c4d (147 KB)
Yes, it’s the Geometry Axis node. As all my lights are in a Null it affects them all. But I just realised that I can put the light I want to change the axis centre of into a child null and put the Geometry Axis node in that.
… or just make a light material for that light. That might be easier.
Thanks for your input.
Even having all lights in a Null does not matter when you place the capsule as a child of the one specific light.
