Animating vray cam crashes max
Has anyone experienced this? Max 2011
Create a vray camera, set key, make a keyframe, scrub the timeline to say…frame 10, move the camera, crash. Auto key works without crashing, but set key crashes max every time.
Ok, yes this is the exact issue I am having as well using set key, thanks for the tip - Autokey seems to work fine
I had a similar problem in Max 2011 and 2010 and solved it by removing the second version of the Brix plugin and reinstalling the first version. Perhaps this helps.
