Animation and HDcache
Is HDcache calculation view dependent ?
only partially, in most scenes you should be able to reuse single cache succesfully
Seems to work.
Do you think it’s useful to render HDcahce at a higher resolution ?
no, change position sensitivity instead
Lower or higher ? Documentation is not very explicit, what does it do ?
higher = higher quality, slower rendering = same as rendering in higher resolution
Ok thanks.
