it comes from the sun..other passes are clean…here’s only the sun pass with the problem.
artefact are comes a frame randomly…and its no coplanar geometry..checked.
any idea?
Setting:
PT/PT
Moblur cam + object
new light solver on
global fog
This looks like the new light solver issue. Can you try disabling it?
This should be fixed in Corona 3 Hotfix 1, so if you are using an older version, updating should help.
If you are using v3 HF1, we are definitely interested in investigating this.
