Animation flickering
Hi, what can we do to avoid camera flickering issue? I read somewhere that it is mostly by emissive materials, i removed all emissives but it is still the same. Especially when in look around animations it is crazy. I have an interior with a lot of reflective and refractive surfaces and a lot of 4d animated people models in the scene.. I tried medium and high presets, 1920*1080 resolution and 8 to 12 samples.. An example video in the link :
Hi, apologies for the delayed response. When rendering animation sequences that include artificial lighting (or other render intensive elements), the required sample ranges may vary significantly. In such cases, it may be advisable to start with values as high as 100+ samples per frame, and move upwards until the result is satisfactory.
We recommend evaluating each project individually by exporting draft sequences and testing different sample ranges to determine the most suitable and efficient settings for your specific scenario.
Thank you.
@kenancakir hi, out of curiosity, did you succeed in rendering your animation without the flickering?
Hi, i was able to reduce flickering by adjusting some values, like motion lenght and fps, but my trial time is gone..
