Hey
I need help to get rid of flickering in my animation. My noise threshold is 5% and I use default denoise values. The flickering is most obvious on the white walls. The scene and video is attached.
(removed)
Petter
Hey
(removed)
Petter
This looks like conventional UHD cache flickering. Make sure you have the Preset “Animation” selected in Render Setup → Performance → UHD Cache (or a pre-calculated cache file which is reused for every frame).
Good Luck
