Hi there,
Recently (last 3/4 weeks or so), our whole studio has had an issue where when we’re working in a Corona Camera viewport, sometimes it will just randomly leave the Camera and switch to perspective without us pressing anything. Usually this is a little annoying but takes 1 second to just hit C and go back to the camera so it hasn’t been an issue.
However this past week we’ve been working on two large animations, and in every sequence of 300 frames (on average), we’re getting 10 or so frames which are rendering as perspective, and not the camera that is selected.
Is this a known issue? Is there a fix/workaround?
Thanks very much!
I haven’t heard of this issue - we will need a lot more info though. Which host software, which OS, which version of Corona, can you send in a scene file where this happens, is it always the same frames that show the problem if you re-render the animation or does it change randomly, are you using any sort of network rendering so that multiple computers are involved or is it all being rendered on the same machine, when you say it will just leave the Camera view and switch to perspective is this during rendering or just during modeling etc (and is IR running at the time this happens)? etc.
See https://coronarenderer.freshdesk.com/support/solutions/articles/5000524006-how-to-report-issues-3ds-max or https://help.c4d.corona-renderer.com/support/solutions/articles/12000033461-how-to-report-issues-c4d depending
Links to the private uploader are in there, as well as guides to the sort of info we need to be able to reproduce/diagnose a problem. Thanks!
Have you experience the same issue with newer versions of Corona?
