Hi everybody
I have been on Corona for about a year now and have eventually started running some short animation over the weekend.
I have found that there is terrible ghosting on the frames.
Not sure where to start…
Im using standard camera , with a 90mm lense and 100mm film sensor , was using this for DOF , which I originally thought was the problem , only to find when I turn DOF off it still ghosts.
Im Using path trace then UHD.
Sorry if its too obvious but could it be motion blur thats causing the ghosting? Also, it would be great if you could upload a frame or two so we have a better idea on how to help you
the camera has auto adjust verticals , and the target moves through the scene , initially this was setup for DOF , but now since turning DOF off I suspect it wont matter
Ok, very courageous from everybody to use this, since it provides the weirdest problems since ever in Max - regardless of the company implementing the camera :]. This should be the cause of the problem. You tested without? And is it a Corona Camera?
I think you can safely switch on DOF (if you like), there should be no issue. Additionally you could test if it works using a CoronaCam (there is no reason not to use it).
