I will have to do some engraving animation in the near future and i need some ideas or pointers on how to do something like this. The model part itself is not a problem, where i struggle is on how to animate the whole thing so it looks like a machine is engraving something. Here is very simple video what i am after, unfortunatly the tutorial linked to it doesnt exist anymore.
So far i tried the slice modifier in combination with boolean - doesnt work because of the infinite slice plane which makes it impossible to animate the slice plane to go around corners. A Path deform in combination with boolean is not accurate enough…
wow that was fast, i will try it but i guess i will run into the same problems as when using a path deformation modifier. Sharp 90 degree corners are always causing problems. If nothing helps i will do it in after effects in post but i havent given up yet to find a solution in max
Just wanted to report back that i got pretty good results using an animated displacement map. Not sure if we will use this method once we get the job but it worked very well.
