Animation IM issue
Hi
I’ve been using Vray for many years but I must confess, the following issue has plagued me all my working life when making animation. I dont usally make animation so always seem to forget something. Hopefully its a really simple workflow issue I have not considered and I can move past it.
When using the 3 phased flythrough or the more recent 2 phased IM prepass/rendering I’m experiencing an artefact issue when rendering the animation. See attached image.
As a way to override my workflow issue, I installed SolidRocks pipeline, and even when using their script I have the same issue, which worryingly would suggest it’s not my workflow but something else.
Sometimes the vray massage box might say something like “issue loading IM” but on this occasion/this animation, I had no errors. All render nodes have permissions to read and write to the folders.
With IM Mode (prepass) its OK to render these frames across many render nodes or does it have ot be calculated on one machine using distributed rendering?
Thank you in advance.
Regards Rueben
I didn’t know anyone used IM anymore .. we ditched it when version 3 came out. No more headaches :smile: … hope someone can pipe in and help you though. :slight_smile: From when I last used it, prepass can be ran across many nodes.
I just rendered the IM on one machine using DR and I still have the same issue when rendering the final image.
So are you using BF/BF or BF/LC?
BF/LC I don’t have to weep in the corner when having to render animation, which is most days :smile:
