animation in Vray
I realize this may be a stupid question and I apologize for it but I simply don’t know how to do an animation sequence in Vray…
Let’s say I have 5 Sketchup scenes and I want to do a rendered animation walk through…is it possible to do? Thanks
Re: animation in Vray
yes, all u have to do is to enable animation, choose a first file name fo exemple: video, so the vray for sketchup will creat the others like video 0001, video 0002, video 0003… ok, u have to choose the number of fps (frames per second)if u choose 30 remember that sketchup stay in one scene 1 second befor start change, and the first one, i dont know why it, stay 2 seconds, befor vray start to render the next moovement of the camera, it will render 30 or 60 imagens of the first picture. Every scene it will be the same, render 30 frames to start moove againg.
You can change settings in sketchup to reduce the time of “stopping” in each scene.
Than when every thing is finished, all u have to do is joing all the imagens in one video, you will pick up all images and put it all together.
Well that’s it, i’m happy to wright this befor any one say, look for it on forum! this is horrible.
And sory for my english.
andeciuala
thanks a lot for the tip…I will try it out!!
how can i put togther all my images wich program did you use???
you’ll need to use a video editing program such as Premiere. Most of them, for putting a quick sequence of images together, are fairly easy to work with. After importing in all of the images then you will be able to export a quicktime or avi
