Animation, inconsistent auto-tilt Shift
We are a small studio, we just add our last big workstation AMD 3970x to the render farm, and we get into trouble.
We have a camera sequence on a corona cam with Auto tilt Shift enable, All frame render correctly execpt all those of the AMD 3970x.
The 3970x OVER/Under tilt shift
All pc have 3dsmax 2021 update 1 / corona 5 hotfix 2 , forest/rclone/… are all uptodate.
Is it and know issue ? Does Auto over and animation is a bad bad bad decision ?
thanks !
Last Update,
Our other AMD 2970wx Station, does a bad tilt shift too .
Sorry, but I did not understand the parts in bold. Can you please explain what exactly you mean by that?
Are you just rendering a sequence with a Corona Camera with “Automatic vertical tilt” enabled? Or are you doing something in addition to that?
Are you by any chance instancing your cameras? (have at least one camera which is an instance of another camera)
Hi Maru,
“Is Automatic vertical tilt + animation a bad (bad bad) decision/choice”
(Auto-completion + auto correction are not good using a foreign language)
To answer :
There are no Instanced Camera in the scene.
We click Automatic vertical tilt, as in your screen grab.
There are no other special thing, just a moving and rotating camera.
Sorry for the delay. Could you please share the scene with us? Or even better, a simplified version of it.
So far, we were not able to reproduce it.
You can use this uploader and then let me know which upload method you used and what was your file name: Chaos
Just checking if there was any resolution to this… I’m having the same issue…?
I lodged a ticket with support, but wanted to check in to see if there is a solution…
using max22 and corona 8 - animated corona camera with auto vert shift on…
also rendering on a 3970x and 2950x fwiw…
thanks.
we are still waiting for a good Solution for this problem, Have same issue in my files too
If you haven’t done it yet, please submit a support ticket here and attach your scene to it: https://support.chaos.com/hc/en-us/requests/new
So far, we are unable to reproduce the issue on our end. We will gladly test other scenes you can provide.
