Animation - losing frames
Hey guys out there.
Anyone experienced losing a bunch of frames during animations?
From 200 frames, this morning 106 were simply gone. No chance to recover them.
Pretty angry!
Again… frames lost.
This time despite having switched off computer sleep mode / screen saver, etc.
Dunno if this is a Corona problem or related to C4D :confused:
Hello Designerman77,
I have just tried to render a scene with 107 frames with both native C4D renderer and Corona renderer on Windows 10, C4D R20, Corona v6 RC2. Both have resulted in 0 loss of animation frames.
Can you please share some further information with us? Such information would include:
OS and Hardware specs
C4D and Corona version
scene in which the bug is reproduced
I will try and render the scene on Mac later today.
Thank you,
Jan
EDIT: logged internally @ 547459475
I have tested it on Mac as well, C4D S22, Corona v6 RC2, still did not lose any animation frames.
Can you also attach a print screen of your render settings?
Thanks!
We’d need more info please - when you say lost, what do you mean? The frames are being saved to disk, (ie save file is enabled, and a filename and filepath given)? Are they there to start with, then get deleted? Your screen shot just shows the PV render history, and I don’t know much about that personally (never use it as a way to check frames, I always save them to disk)
Also of course, Corona version, C4D version, OS version, etc.
EDIT - also, were you using Team Render at all, or was this all just one local machine?
Hey Tom, thanks for your reply!
Yes, the .mov-file has a file saving path.
Update on the strange frame-behavior from yesterday: when the rendering of all frames is completed, the first 22 frames that - as you see, first disappeared - reappeared again in the end.
So, I guess the system kind of deactivates them during the render process… for whatever reason. Maybe to save RAM? I can’t really imagine this.
I have seen this strange behavior also on former test renderings in much lower resolution, that take much less RAM, etc.
So I guess it might be a bug in C4D? Or in Corona?
System: C4D R21, Corona V5
OS catalina 10.15.
Mac Pro 2019 16 core, 3,2 GHz, 48 GB RAM, Radeon Pro W5700X 16 GB
Rendered only on one machine, no TR.
Hey, thanks for asking.
Render settings are left totally basic. Only the noise level is on 4.
Resolution: 1920x1080
Hey Jan,
as mentioned meanwhile bit lower: I noticed that the frames seem to disappear during the render process - and seem to re-appear when rendering is finished.
If you save the movie manually during the render, your missing frames will also be missing in the saved video file.
And in case C4D or Corona might crash, of course no chance to get the frames that were “deactivated” during rendering… as they only reappear at the end of the complete render process.
BTW, never render to .mov or other animation format, always to a series of still frames, and composite into animation later.
  • If the power goes out in the middle of writing an animation format, you have to start the render from the beginning. With a sequence of stills, you just start from the first still that was not rendered already.
  • If you discover your animation compression is all wrong, you have to start the render from the beginning. With compositing stills, you can tweak the movie compression in post just by re-encoding the stills
And so on :smiley:
Hey Tom, thanks for the tip. Yes, I had read about this a while ago in threads.
Gonna do it in future.
But right now I was too lazy to bother with one more step in the workflow. :smiley:
The frickin project is already so complex that my mind says: “let me rest bit”. :))))))
General question to all of you guys:
I do get some non-beautiful flickering, big splotches in some areas. Could it be from too high denoising (0.8) ?
This would be my guess.
In the yellow balconies.
Noise level is quite low… 4
Looks more like cache flickering, UHD Cache for example if you are using it. Make sure “Animation (flicker free)” is checked for the Cache, rather than “Still”. You could also try calculating and saving the Cache. See https://coronarenderer.freshdesk.com/support/solutions/articles/5000515648-how-to-use-uhd-cache-for-animations-and-stills-
Or you could try using Path Tracing rather than a Cache (or you could try the 4K Cache, if you are using Corona 6 RCs, just to see).
Hi Tom, thanks a lot for your reply.
Flicker free is activated.
I did not activate saving the precomputation file because in my tests this resulted in visibly wrong GI on many surfaces.
It looked like there was an additional light source in the front of the scene…
Strange…
As GI solver at the moment I have the UHD on.
Gonna stop the animation and give it at try with the path tracing as secondary solver.
Regarding the 4K cache: is 6 RC already stable enough?
Would have loved to give it a try - especially for the 4k-cache… but haven’t dared, since people report so many bugs.
I guess I’ll give it a try anyway… :smiley:
P.S. Would you recommend to lower the denoiser (0.8 currently), since my noise level is anyway set to 4% ?
Thanks in advance!
Yep would recommend the denoiser - unless you run til noise is down to about 2%, denoising is a good idea (and sometimes even then).
Doing a “generate the UHD Cache” using Load and Append as mentioned in the article, rather than use just one saved UHD Cache from the first camera position, may be the best option. Still shouldn’t look THAT different though, and certainly not like an extra light - feel free to share a comparison frame that shows the differences, or raise a bug report via forum or ticket, if you think something is not working as it should.
The 4K Cache is still experimental in the RCs at the moment, so, it may be worth a try, but definitely keep a version of the scene NOT saved from Corona 6 (as once you save it in Corona 6, it is not guaranteed to work in Corona 5 and earlier). Do treat it as an experiment, and take all necessary precautions!
If you use Path Tracing, you may (or may not) get better results, but it may take more time to render (in this case, the lighting in question is on the underside of the balcony, so is almost certainly bounced light of some sort, which is where the Caches come in). May still be worth trying though, as avoiding any flicker can be more important than overall render time.
Let us know how you get on!
Hey Tom, yes… seems like it was caused by UHD as GI solver.
Switching to path tracing eliminates that ugly GI splotch-flickering. But: it also calculates ca 20% longer… :confused:
P.S. after having saved the UHD cache to a file, should the menu point “After Render” be set back to “discard” ? Or can it remain on “save” ?
EDIT: problem solved thanks to your hints, Tom.
Saved the UHD cache. Now those splotches are gone, PLUS the renders now take 11% less for every frame. :smiley:
That’s one hour less for those 200 frames and for sure 4-5 hours in the whole project.
Very cool !
General observation: using “path tracing” as secondary solver generates a visibly nicer, less biased light calculation.
But the increase of 10-20 % render time is not worth ist in this specific project.
For other projects I will consider it though.
Thumbs up to you Tom!
Again showing how great the Corona customer “doctors” are.
None of our questions is too “dumb” for you guys, you are always going help.
10/10 !
One more question, Tom:
at noise level 4% I find many surfaces - such as building walls - to still show too much noise. In the animated camera movement it gets much more visible as flickering
compared to still images.
Denoiser is already at 0.8
UHD is cached. So I would expect even less visible noise & flickering.
Yep, “flicker free” is also on.
Going lower with the noise level to 2% or even lower is no option for me…in terms of render time going exponential. And I find in general this is e very extreme step.
Not everyone has set up a massive render farm.
Do those walls have bump on them? The Corona HQ Denoiser does less denoising where there’s bump (to preserve detail) so that could be the reason, would be interesting to see some frames. Various things you could try, such as, a VirtualBeauty with even higher denoising and a mask for the walls (eg Denoising of 1) and compositing that super denoised version in post; or you could try one of the AI denoisers, which don’t know about the presence or absence of bump in the scene so denoise equally.
Of course it might also not be rendering noise, it could be other things, such as just the bump catching the light differently from different camera angles, or displacement set to screen space rather than world space and changing resolution as cameras move. Again, impossible to say what kind of flickering/noise is present without seeing the result.
Also, is Sharpen/Blur used? That can help, if not.
Hey Tom,
thanks a lot for your reply & suggestions.
AI denoiser is already used in the scene for reasons you mentioned. I actually always use the AI denoiser, since it doesn’t mess up bump maps & round edges.
Yes, a little bit of bump is used on the walls. But from that big distance, it actually should not have a visible effect… in my understanding, at least.
But who knows.
You mentioned UHD caching with the “load & append” method. What is the advantage compared to simply “load from file”-method?
Thanks in advance for getting back.
Well, you would use Load + Append while generating the saved version of the UHD Cache - this basically calculates the cache for one camera location, then loads that and calculates the cache for another location adding that result to what was calculated before, and then repeat as it goes through the animation.
Then you simply Load when rendering, as the cache has information from various camera angles added in to it. A good example is to think of a camera starting in one room, and moving through a doorway into another room - if you only calculate the cache from the first room, nothing is calculated for the second. With load and append in the calculation phase, cache information for both rooms is generated.
(You don’t really want to use load and append during rendering, as then you are pretty much just calculating the UHD Cache each time and would be as well calculating from scratch - so it’s during the generation phase you want to use it).
Hey Tom, thanks for the explanation… despite it’s late at night. :))))
“Load & append” takes all camera positions of an animation into consideration, from how I understand you?
Which should actually be a big advantage… ( that may even eliminate that flickering occurring due to every new frame / camera position change).
So, “load&append” is chosen only while generating & saving the UHD cache. After finishing the calculation of the cache, one switches back to “load from file” during the rendering process.
