I’m trying to render an animation with Vray3.6, 3DMax 2018.4, IM-LC using animation prepass as described in this link (Chaos Docs).
The animated assets are distributed using forest pack with Limite to visibility checked.
I’m having two issues with this approach.
First, it only renders the last frame. (Main issue)
Second, It looks like it’s using the first frame camera perspective to do the visibility of the distributed objects. so the last frame that is rendering is only showing the objects visible on the first frame. (I think this should be sorted once IM-LC start from the first frame).
Has anyone encountered this type of issues?
Thanks in advance
David
