animation prepass with negative "active time segment" does not render light solution
hello,
if you set the active time segment to begin at frame -2 at animation prepass, the whole sequence does not render correct light solution.if you set the active time segment to begin at 0 and render “range” from -2 to… it works.
thomes
vraxnext update2 / max2019.3 update
Would it be possible to send a scene to philip.shounev@chaosgroup.com to take a closer look?
Philip
mail sent. thanks for looking into
thomes
Hi again,
It seems that the saved .vrmap files are empty when the active time segment starts with a negative frame number and “Use camera path” option is enabled. A workaround for that would be if the active time segment begins at 0 and the render range - from -2, as you have mentioned in your previous post.
Best,
Philip
…for sure they are empty… there is no visible rendering of the passes
Thank you for your feedback. I’ve logged that in our bug tracking system under VMAX-8901.
