I tried to render an animation and run in following problems:
* alpha can’t be disabled (I like the render background and want to see the background at my frames) - works at VFR2
* alpha channel saved to disk (waste the output dir) - works at VFR2
* I like to use the denoised output only, than the undenoised RGB version can’t be disabled and is wasting the output dir and needs manual deleted
* also if I set the Rhino task in the background and work on other software in the foreground, than I lost the connection to my foreground task if a frame is ready - so, the machine can’t be used during rendering an animation - works at VFR2
