the renders of the same architectural interior scene produced in vantage via vrscene and the renders produced via live link by 3ds Max are different.
The renderings with vray scenes present artifacts on the shadows, near the ceilings and walls. The problem is much less obvious when rendering live link with the same settings on vantage. I rpovasto to also disable the Ambient occlusion, lower the GI but the problem is not solved.
Please provide screenshots and even better, a scene that we could use to reproduce the issue (if possible, delete parts of the scene to keep it small).
this is the effect from render by vrayscene.
The file is very big because it is a big project.
Hi poliedrostudiosrl_poliedrostudiosrl,
Sorry for the late reply. At what setting have you rendered the sequence? I have tried to replicate the scene and couldn’t reproduce your issue.
Alexander
