Animation render half size in every next frame.
My 800x800 animation renders 400x400 the next frame, and 200x200 the next frame and so forth. Did i check/uncheck something?
Thankz
https://sneakybiscuit.sslpowered.com/misc/anim\_test01.mov
Like this :slight_smile:
That is absolutely bizzare.
You aren’t rendering straight to .mov are you? (It’s a bad thing in general if you are)
Which V-Ray version is this? Are you using Crop rendering?
I’ve seen the movie, “the Incredible Shrinking man”, this must be the incredible shrinking animation. Have you been near any radioactive clouds recently?
mh
I am rendering straight to a .mov. Its only a quick test render so didqint do individual frames.
I AM crop rendering
I am using vray 1.5 RC3
