Hello guys, again this problem of difference between IR result and FR in Animation! When I simply save the image from IR in PNG format it’s satisfying and enough but the saved frames…
Does the new OCIO OT has any role in this issue? When I simply save the image from IR it looks correct but the animation outputs are extremely dark. What’s the reason? If the OCIO OT is only a tone mapping feature, could it be the reason?
In one word what should I do if I wanna see the final render the same as the interactive render result? Even the extracted Lightmix channel of the EXR in After Effects is very saturated, high contrast and totally different, indeed disgusted..
Thanks,
