Info;
Rendering out a 450 frame animation
3DS MAX 2016
Corona 1.5.2.
Elements set to save onto network - PNG / EXR Default compression options.
The render saves out perfectly, it’s just the elements that seem to be messing up.
See attached file for the error.
What could be causing this? At the moment I have to use tiff’s to get any passes out.
---- It should also be noted these elements are around 77-115KB each the render that is working perfectly is 10853 kb
– Also second note this is file / project specific I have an interior rendering fine.
